Smart Thermostat for Ancient Wall Furnace
suckerformimi
I have an old 2-wire furnace. How do I connect a smart thermostat to it? The furnace only supports 2 wires and takes no power. It has a pilot light and presumably a pilot generator. So I think I need a solution that gets the power from something other than the furnace.
Thanks for any help here. I have been searching all over.
herm0016
8,507
1,122
iThe ecobee comes with a transformer. you may want to give them a call just to make sure it will work though. I am not sure if there is a minimum control voltage that it would need to pass in the transistor? i have installed them on 2 wire systems, but not one powered just with a millivolt generator.
Feb 4, 2009
35,862
17,401
As above ecobee seems to fit nearly everything and at least as of four years ago their support & sales support is first class.
deadlyapp
6,654
734
You should be able to hook up any newer thermostat, you'll just need a separate transformer that will provide your "C" wire since your furnace may not easily provide it (although likely does if you pull it open).
herm0016
8,507
1,122
sounds like its old school with a millivolt generator. no transformer or control voltage needed.
Sukhoi
15,346
Check how many wires are actually in the wall. If you're lucky they ran 4-wire instead of 2-wire. You might be able to use a transformer to provide the C wire at the furnace end and use a normal thermostat, which will look nicer than having to run a power cord from the thermostat.
