Smart Renaming / file naming system?
Imaginer
Ever run into a problem where you want to rename multiple files but have to rename them individually one by one with one change being a word/number/phrase?
I would hopefully like Vista to incorporate something like a smart naming system where you can rename multiple files or tell multiple files to be renamed with <insert words you want> in the file name at a certain location specifically.
I hope I am not the only one alone in this boat....
And I would like to file that as a suggestion - but I am not a tester or developer. Just a average user.
Sure, and it's dead easy with *nix. Vista afaik isn't doing any shell upgrades. They took out Monad that was supposed to be a revolutionary shell to be released at a (much) later date.
someone posted a way to mass change filenames a few weeks ago on WinXP...so that you can make an entire directory filename1, filename2, filename3, etc
Monad or MSH is to be included with Exchange 2007. Monad will be released sperately at that time. So you should see MSH within 6-8 months after the Vista launch.
I can't wait for MSH. I've been using the beta for a while now and it's very powerful.
I actually learned how to change multiple file names at once by accident.
I had a directory with my camera pics in it that I needed to merge with another pic directory but all the file names were the same. So I proceeded to rename a file but I had unintentionally did a "select all" and after I finished the rename all the files in the directory where renamed as well.
All done from with in windows XP with no special tools installed😀
