Smart Phone Remote wipe question
chuck2002
We are running new model Treos and would like to do the remote wipe function from our Exchange 2003 server. We have the remote wipe setup and functioning, however when the Treo gets the remote wipe command, it prompts for user interaction. It says the Exchange server would like to apply a policy to the Treo, would you like to allow this and gives a yes or no.
If the phone is lost or stolen, asking whether it is ok to apply the wipe is not desirable. Has anyone seen this and found a workaround?
Thanks.
-Chuck
Have you updated the Treo OS and enforced device policy?
There should be a flag in there that can disable prompting for new policies, including remote wipe.
Also, possibly Wrong Forum? 😛
- M4H
