phucheneh
With battery chargers, my hatred for them has generally followed the curve of technological 'advancement'.
I hate the hell out of five-figure (in some cases, in the 5-8k range) computer-controlled chargers. The ones I've used will try to charge anything, and they'll do it in the most dangerous way possible. And when you actually WANT them to charge, the best you can do is set a 'preferred' voltage or amperage setting. It doesn't matter what you put; you're gonna get a ~2a trickle any way about it.:|
I picked up some free tools a while ago and got this:
I'm not sure how old it is. I'm guessing 1960's, maybe 70's?
It's become my standard go-to battery charger. No, it doesn't shut off automatically or do any kind of metering on-he-fly. It just puts out a constant voltage and current at or above its rated capacity so long as the battery needs it.
I can't remember what I measured the output voltage at. But it's dead-on with the manual (found one online). When a battery is being charged, it sticks around the rated output (5-7a). A very-dead battery will take about 8a. When it hits 3a, according the manual, it's fairly well charged (and it is...not 100%, but a good 60-80, at least). Actually damaging a battery with it is possible but would probably take a pretty long while.
Anyway...I think I forgot what my point was. I think it's that I like old bulletproof tools over some cheap Chinese circuitry, however much more complex it may be.
