SMART® PyxScape SV3170 17" LCD Monitor 329 AR
FlapJack
this monitor can be had from BUY.com for 329 after rebate...
It appears that shipping is free
analog input only and 25ms responce time.......
Features Display Type: A color active matrix TFT LCD display.
Diagonal Size: 17"
Viewable Size: 17"
Viewable Angle: 140 degree horizontal, 110 degree vertical
Tilt Angle: +3 degree/ -45 degree
Wall Mount: Yes ( Optional )
Brightness: 250 cd/m2
Resolution: 1280X1024
Display Colors: 16,194,227
Pixel Pitch: 0.264(H) x 0.264 ( V)
Interface: Analog
Video Input: 15-pin mini d-sub
Contrast Ratio: 450:1
AC/DC Adapter: Input:100~240VAC, Output: 12VDC, 3.33A, 40W
Plug and Play: Yes
System Type: PC/MAC
Power Requirements: 35W
Power Management: VESA DPMS
Power Consumption: 35W (Max)
Response Time: 25 msec
Weight: 4.2 kg
Dimensions: 14" (W) x 15"(H) x 7" (D)
Seems like a decent deal to me........ Whats the concensus?
Link
LINK TO MONITOR
Man you guy's are a tough crowd......... whats the big deal 25ms pretty good aint it?
Granorense order 2 I cant afford it myself
Double repost (though the price has changed recently [it has gone up]).
If you order this, make sure to use the $10 off coupon that is floating around. I thought there was a $15 off coupon for Buy.com, but I don't see it on a quick search.
As for being a tough crowd, I think a lot of people these days want 16ms response time and, if possible, true 24 bit panels. LCDs are relatively expensive. If you are going to shell out that kind of cash, you might as well get a good one.
This is a good price for a 17", 25 ms LCD, though.
