Small SQL problem
PowerYoga
4,603
I'm new to SQL and I'd like to link 2 computers together, with one computer acting as the server with the SQL server while the other acting as a client.
I instaled SQL 2000 eval version on the server computer with everything, did databases and everything. Now I installed client tools only on the client computer and i can't figure out how to link the 2 together. When i try to add a new database for the client computer, it would just say something like "xxxx is not found or does not exist".
Are there specific steps that I can follow?
Thor86
7,888
7
You'll need to use Client Network Utilities to add the server "alias" so your Client Enterprise Manager can connect and manage your SQL DB server.
The built-in help is a good starting point.
PowerYoga
4,603
add an alias to the client or the server?
PowerYoga
4,603
new update... i figured out the reason why i couldn't connect to the host SQL computer was because of the windows firewall.
now, i am trying to add the server so that it can connect to the SQL server but when it prompts for a user name and password i'm stumped, as i never did set user name and password except for the databases.
Those user name(s) and password(s) are not the ones that you use to log in to the server, and i can't log in using guest accounts.
is there a way you can create an account?
