Small small ATX cases
mcgrath
32
anoyne know where I can get a very small ATX case similar to the new shuttle cases? I dont want to have to buy a new motherboard or components, just want a small case. please help
cliftonite
6,899
63
If you have an ATX motherboard, I dont know if it will fit into a small, small case :( You will need to invest in new components. So you may as well get the shuttle :)
DaveSimmons
40,730
670
A full-ATX motherboard won't fit into a "tiny" case -- the smallest ATX towers I know of are still about 16.75" tall (for example Inwin IW-J523N). A micro-ATX case is smaller (Inwin's IW-V523P tower is 14" tall) but requires a micro-ATX motherboard.
So if you want small, you might as well get a Shuttle.
ElFenix
102,396
8,559
i think via has an itx format or something like that but you might as well get the shuttle since its a complete solution. they thought of everything so you don't have to.
Bleep
I posted about this once before but I think you will get a laugh.
I sold a ATX motherboard to a fellow and the next day he called and said the MB would not boot, I went over to his house and he had a Mini Tower case, I looked in the case wondering how he got it in there, he simply sawed off the isa end of the board because he did not have any ISA devices anyway.
Bleep
eplebnista
24,123
36
Bleep
:Q :D
Windmiller
10
I noticed LIan LI has two on there webiste. They areprobably a little expensive....I just bought a Lian Li PC 42....it is not as small as the shuttle cases but its small.....
