Small, quiet heatsink/fan combo?
Kevin
3,995
I'm looking to upgrade my stock AMD heatsink to something a little more quiet. I was very close to picking up a Thermalright Ultra 120 Extreme but then I realized it probably won't fit in my case (Coolermaster Praetorian atc-201). Any suggestions? Most of the reviews I've cruised are of these huge heatsinks that according to specs, are bigger than the 120...
DSF
4,902
The Ninja Mini is a pretty good heatsink.
I'm happy with the BTF-90 I have inside my Solo. I don't know for sure whether it would fit in your case, but it's smaller than a lot of the really monstrous ones.
Kevin
3,995
I picked up the BTF-90 and it fit perfectly. My motherboard tray just slides out with it installed. Thanks for the recommendation...
