Small problem In IE
Eminem2k1
I just noticed that IE downloads all .Zips as OPEN as.. into the Temp folder, and it a pain to remember to do save target as.. so how do i make it have the popup when i click on .zip links? thanks
did you recently install some decompressionp rogram like winzip? look in its options whatever you have.
nope , i havent the only thing for.zips is winrar which i installed a few months back so i dont think it has anything to do with it.
Originally posted by: ffmcobalt
Okay, here ya go. If this doesn't get it fixed, then it's not an Internet Explorer problem, but some other embeded issue...
<a class=ftalternatingbarlinklarge target=blank href="http://www.ffmcobalt.com/iefix.htm">clickity clickity</A>
nik
that dosent help in XP because IE is a windows component
figured it, if anyone cares..
In regular explorer (not internet explorer) go to menu extra, folder options, file types, zip, advanced, click confirm open after download.
