- Dec 11, 2017
- 1
- 0
- 1
I'll bring you up to where I'm at right now.
2 days ago a few drops of Ramen water(salty) spilled over my top case fans while setting it aside. Almost immediately my displays turned off but my computer/peripherals were active. Once I turned my desktop back on I had a message "Please connect PCI-E cables to this graphics card and restart." I removed the GPU and used the on-board graphics for a while. 6 hours later the I could use the GPU as usual but the displays would turn off randomly anywhere from a minute to an hour and I had to restart. Since I started using the GPU again today it's been working perfectly.
But I have a new problem.
My on-board sound doesn't provide any audio, but just sounds like a quiet teapot with intermittent static.
I've used different speakers/headphones. I've ran a different power cable to a separate spot on the wall. I've removed GPU, SSD, RAM, etc. Unplugging the PSU, or disconnecting the MOBO will stop the humming.
Unless something in my description jumps out at you, I'd like to know what to keep in mind if I try to clean out any residual Ramen water. From what I've read I assume the interference is caused by residual conductivity from the spill.
I'm going to brush around the front half of the motherboard where it could have dripped with a clean toothbrush and isopropyl. Any other suggestions?
