Small problem after install of K7S5A, need help?
mikef208
Banned
Nov 30, 2000
3,227
The install seemed to go fine and it went through the BIOS and seemed to detect everything at boot. Then it began to search for a boot record, which it didn't find. I rebooted and realized I needed to set my LS120 as the boot device instead of floppy. So then it goes through it's stuff and starts to search for the boot record. It says Searching for Boot record from ARMD Floppy, then it says OK. But it hangs there and doesn't go any farther, whats the deal?
Tol
285
For some reason, when switching cables around in my computer using the K7S5A, I always have to reset CMOS. Luckily, that jumper is easy to reach in my case so it hasn't bothered my too much.
mikef208
Banned
Nov 30, 2000
3,227
I will try that, but i didn't switch cables around, this happened right after the first time the machine was set up
DAPUNISHER
32,116
32,692
What O.S. are you using? Does the firmware on your LS120 permit upgrading? if so has this been done?
