- Jul 11, 2001
- 37,510
- 8,102
- 136
Many years it's been that the detached garage has been in poor repair (I've tarped the roof yearly for 17 years or so) but my recent home insurer was going to pull the plug on my policy because I hadn't moved forward on fixing the garage. They relented when I showed them my contract to have the roof repaired. The roof job is now nearly complete (the roofers will install a couple skylights when they come in ~next week).
I fixed the door some years ago. It needs to be repainted, I figure to tackle that this summer. There's one thing remaining:
Two walls are cinder blocks, they look great (whoever mixed that mortar knew what he was doing!). The 3rd wall (a side wall) is delapidated. It's framed with 2x4s, actually has a couple of windows ( ! ), and it looks to me like there used to be a door in it! That door's long gone, the windows were busted out years ago. Someone slapped just anything they could find on that wall to keep out the weather... old doors, used plywood, whatever. A small portion of that makeshift siding is wooden slats. I'm in the process of removing everything down to the 2x4 framing. My roofer suggested then applying "felt" for moisture proofing (15 pound, he said), and then something like "Cemwood" siding (he said it's probably called fiberboard at the local lumber yards). I asked him if Home Depot would have that and he seemed to doubt it, said I should check the lumber yards.
I don't want any windows or doors on that wall, see no reason for that. I'm removing all that stuff. I want just a solid wall.
So, my questions are:
1. What to use for siding? Will Home Depot have it (I figure their prices would be competitive and I can rent a truck there for transport 1/2 day or something pretty cheap. Of course, I could get stuff from a local lumberyard delivered, but it would probably cost more than renting a Home Depot truck).
2. Just tack up cut-to-fit 15 pound "felt" like he says, and hammer on pieces of fiberboard? Alternative materials, methods?
3. The 3 feet or so where the door must have gone has smooth continuous concrete at the bottom, inside and outside past the wall. I figure I shouldn't just butt the fiberboard (or whatever) to the concrete, I have to do something there before applying the siding. I'm thinking maybe get something like a ~3 foot pressure treated wood 2x4 or some other dimension and attach that to the concrete in some manner, maybe a caulk/adhesive of some kind that will stand up to the weather (it doesn't freeze here but once every few years, and the lowest temperature I've experienced is maybe 26 F back in 1991 or so). Once that piece is attached to the concrete I can attach the bottom of the siding to it.
4. Paint the siding somehow? If it looks good without paint, fine, but I want to extend it's life and appearance.
Thanks for any suggestions, comments, etc.
