- Jan 16, 2001
- 31,528
- 3
- 76
This is for my network-to-be, which will be going into my house-to-be.
Planning on a small network (Cat 5e). Basically wiring every room in the house w/at least two LAN jacks. All cables will terminate in a closet, where the server/switch/modem will be.
I know that in big networks, they run the cables to a patch panel, punch down the individual wires to the back of the panel, then use pigtails to go from the panel to the switch.
Is there a purpose/point to doing that with a small, home network?
Why not just put an RJ45 on the end of each cable and plug directly into the switch?
Thanks for your opinions.
