Small latch on side of laptop won't go in! Help!
Ender
Basically on the side of my laptop there is a place for (I think) a network card so I wanted to see if it actually was what I thought it was. Anyway, I pressed a little button that was in the computer side and out poppd a little tray. Now, when I want to push the button back in, as well as the tray, it won't go!
Is there anything I can do?
Follow these steps:
1) Push the little button all the way in (it should click into place). The card/piece of plastic should be out.
2) push the card in
to get the card out:
1) push the little button so it pops out.
2) push the same button all the way in.
3) remove card.
simple...
