Hi guys !
im wish to build new rig on i5 3750K base and i appreciate your help guys .
My actual one is :
CPU :as stated, turbo mode with NHL12 on to of it
MOBO : GA B75MA-P45 - leftover from last combo i bought with i3 2100
GPU : XFX r280X (quite ok but im not as happy from XFX7870 :/ )
RAM :Venegance 8Gb 1866mhz
PSU : CX500M
CASE C 200R
SSD: OCZ 60Gb
Hdd : WD Black 750Gb 2,5'
Its Pc i builded myself with knowledge i had at that time
So i have few questions for you guys
PC will be mainly for gaming in mind (from time to time ) will be connected to TV in living room so it need to be quiet when browsing etc , only 1080P ( aiming at 40-60 fps Ultra) eventually i can change gpu in one year or so but i would not rather.
It will be good if rig can last 1,5-2 years but im worried that my CPU will be not enough in end of the road...?
Im looking into very good (not hi-end , i dont need bells and whistles
mini ITX board so i can utilize i5 advantages ,OC to if possible 4 Ghz if my Noctua can handle it .
Gpu is 780/780Ti range with good OC capabilities or/and low noise
(2014 gpus)
For psu im aiming for silent optimized one -if possible with mini ITX case in mind
Is my ram will be good enough or should i change it for faster one?
Thank you very much for your time .
Gretzz
My actual one is :
PSU : CX500M
CASE C 200R
SSD: OCZ 60Gb
Gretzz
