Small Heat issue with Cpu...
Pixle
435
Ok...so I just finished a build for a friend. Hes had the parts lying around for about 2 months. I even installed a new Heatsink for him (swiftech amd 64 one) + AS5. Its a 164 3400 with corsair 2x512mb , 300 gig maxtor, 6800gt , audigy 2 zs, msi k8n platinum socket 754, x-connect 500w ps, xaser v1000 case thermaltake.
The build went smoothly and it loaded up fine. I loaded the OS...and then my friend says that he would like to add a sensor for the cpu. I tell him ok...but to hold on because I was going to get some food.
When I came back I see that the cpu was pulled out while the socket lever was still down. It seems that the cpu stuck to the hsf while it was being taken off. I ended up not installing the heat sensor on the cpu because of its size.
The cpu seemed to be crack a bit on the sides about three really small (small little cracks) The pins seem to be all fine. So after a talk with him about the consequences of his actions...I finally finished what he tried to do up and installed the cpu.
I waited for some BSOD or even a no post. To my surprise the computer booted up just fine. I then installed motherboard monitor and it showed his idle cpu at 56 celsius and under full load (games) around 65 - 70. Same showed up in the bios.
I thought the HSF might not have had good contact so I uninstalled the HSF...and I put the stock one. I carefully took off the AS5 with alcohol.
I booted up the computer and again - the same high temperatures with the stock HSF.
So my question is: Can Cpu cracks on the silicon contribute to the High heat? Or is the Socket on the msi board messed up from the pull out with lever in place?
Funny thing is that when you touch the heatsink - it isnt hot at all (well the sides - can't reach the bottom)
Your thoughts :) ...
Pixle.
imverygifted
1,368
for starters the msi k8n neo platinum's thermometer is off by alot, its a known issue. also although temps in the 50-60s are very high my old thunderbird ran at around 60-70 load and it worked very well. also it sounds like your applying too much as5 when i first used it i also pulled a cpu out of the socket when i was taking out the HSF, didnt do any damage but probably not something you want to get in the habit of. a real thin layer is best. i don't think your cpu can crack at those temps especially w/ the big heat spreader on the processor
CheesePoofs
3,163
Temp sensors are never right. Run prime95 for a while to see if its stable, if it is then you can ignore the temps becaues if the temps were really that high it would become unstable.
Pixle
435
Odd thing is..when I would play a game..i would get artifacts. pretty bad ones too. Like part of the far cry sand became black. I had the recent vid card drivers..and the monitor is all that needed to be upgraded.
MBM reports the same temp...is mbm wrong?
imverygifted
1,368
try a diff vid card
Pixle
435
The 6800gt...hasnt been modded and it seems to be running at a good temperature - even at load.
I was stressing farcry with everything enabled and res. up high.
