- Jun 5, 2008
- 6,546
- 3,007
- 136
Yes but the screw is already loose and it needs to be a touch looser. When fretting the 12th string it's showing a little bit E sharp.Have you tried setting the intonation? You do that by adjusting the bridge saddles
I really hope it's not the neck. The box had a crease across the middle when it arrived. Oddly there was no packing material in that area. Just the ends of the box :\. I'll try raising the action and if it don't work I'll try inspecting the frets and neck.Can be a lot of things. Higher action might help if you don't mind a higher action. Truss rod could need some adjustment, or perhaps the neck's twisted, or simply a high fret.
Thanks
