small case (mini-itx) that takes atx psu and 5.25 slot
you2
7,140
2,188
I'm looking for a small case that takes an atx psu (since I have an extra one lying around) that has at least one 3.5 or 2.5 slot and a full external 5.25 slot.
I'm aware of the silverstone sg10/sg09 series (actually micro-atx cases) and the cooler master elite 110-130 (mini-itx).
These cases are a little larger than I would like and I ony need one hd and one external 5.25 slot so there is quite a bit of room for triming.
(not to mention that the silverstone cases are excessively expensive);
Any suggestion for a smaller case ?
Feb 25, 2011
16,999
1,628
The cooler master Elite is about as small as it gets, if you're looking to support full-size optical drives and PSUs.
I have a Silverstone SG05, which can be modded to take a full size PSU, but you'd have to get a slimline ODD.
aigomorla
21,131
3,666
+1 for the cooler master elite 101.
piasabird
17,168
60
http://www.newegg.com/Product/Produc...82E16811119286
I use one of these for an HTPC computer. It is really just a simple computer with no video card and just a hard drive and a DVD. I don't really like the drive configuration. I wish the drive mounts were right next to each other. It looks ok.
I have a gigabyte motherboard with a Mini-PCIE AC wireless Centrino Card.
I turned the power supply upside down the remove hot air from inside the case.
Case has a front 120mm intake fan.
you2
7,140
2,188
What advantage does the sg07/08 offer over the sg09 or cooler master ? It seems very similar just different external style - of course the silverstone requires slim drive while the cooler master takes a full drive.
I said mini-itx in the title but to be honest a micro-atx would be a bit nicer (can you squeeze the micro-atx into cooler master case?) since there are these $100 bundle deals with the pentinum.
Would the Silverstone SG 07/08 work for you?
