UsandThem
Just to be clear, it's just one idea I have, and I am not claiming it is definitely the issue.
So with that out of the way, I had an older Roku unit that we used for about 4 1/2 years. It worked great up until it just started becoming obsolete hardware wise, and got slower and slower with each update. About 6 months ago, we moved to a Roku Ultra unit, which was noticeably smoother when starting it, browsing the apps, and searching through Netflix and Amazon movies. However, since we "only" had a 1080p TV, we didn't use any of its 4k capabilities. The unit was smaller than our first one, and would get decently warm when using it (hooked up to a LAN cable).
Fast forward to a few weeks ago. We bought a 4K HDR TV, and signed up for the Netflix 4K service, where some of the shows are 4K (HDR). The Roku unit began not getting a signal through the LAN cable from out of nowhere, so I switched it over to using WIFI, and sometimes it would work, others times it wouldn't (and on a few occasions it would reboot). This went on for about 10 days, where it would work fine for a bit (maybe make it through one 4K movie, or a couple 4K shows), and then kind of become worthless. The unit felt hotter to the touch when using it with 4K content.
So initially I was going to get another unit, maybe the Amazon Fire TV, but then I had a thought when looking at their newest designs. These things are getting more powerful, and 4K content is more demanding, but the units are getting smaller (and are usually sealed with no vents). Maybe that is the issue?
So instead of getting another streaming device, I bought a 4K streaming Blue-ray player, and received it today. I hooked it up, hooked up the same LAN cable, and was able to watch 4K content for much longer than I could on the Roku unit. In fact, I never had one buffer or stutter issue at all, and it worked great.
So anyone have a similar experience with their streaming devices?
