- Jun 14, 2003
- 10,442
- 0
- 0
i had little strands of cotton or fabric or something in my view finder, they werent on the bit where you put your eye, but the bit that sits above the mirror, so they must of floated up there when changing a lens.
now, i tried to get rid of these with a cotton swab.... in hindsight i should of used a small paint brush. i couldnt really get them to shift and so i dampened the the swab very slightly just to make it less fluffy and more tacky.
well that got the fibres off.
but then left streaks/smears! lol
from the sounds of it the glass here has lots tiny grooves (u can hear when you run something over it) so i think the smears were kinda stuck in the grooves. i was like oh sh*t! but then remembered that a grubby print on the viewfinder wont do anything to my photos.
anyway i managed to remove the smears almost completely with a micro-fibre cloth and over time they seem to of just dried out, also managed to get a greasy finger mark off the mirror by lightly running a microfibre cloth over it a couple of dozen times...didnt wanna push on that thing! but i do not wanna have that happen again! next time ill use canned air and a fine brush.
cameras working perfectly so i havent bust anything! thankgod
but just in case, whats the best way to clean something like streaks/smears off that part of the view finding assembly?
