Slowness and Mouser cursor problems
I've been running Windows XP SP2 for quite a while now, and i haven't had any problems at all, all my hardware is working and everything seemed to be going fine.
Just a few days ago my computer started to go really slow, like it seems to be using lots of processor power for the simplest thing like opening up a web browser. Im running an Athlon 64 3200+ with 1.5gb of ram and i've never had this problem before.
I go ctrl+alt+del and look at the process's tab, nothing seems to be using a large amount of ram or CPU power, I don't think i have any virus's or spyware, i havent downloaded anything strange in the last few days. I took my computer apart, cleaned it put it back together and the same problems are occuring. I did F8 during bootup selected Use last good configuring that worked, same problems.
Now just today when its booting up I have my mouse cursor for a while but then it seems to get stuck somewhere, but i move my mouse around and i can select things but i dont see a cursor, its like an invisable cursor. Not sure what's going wrong here, this system is only 6 months old.
What psu?
What RAM?
Can you run memtest at boot - overnite is best.
What other hw are you using?
Have you tried running in safe mode - does the same stuff happen - sloooooow?
Motherboard - ABIT Av8
Processor - AMD Athlon 64bit 3200+
Ram - 2x 512mb Kingston (possibly valuram) 2x 256mb Kingston (possibly valuram)
Graphics Card - NVIDIA GeForce 6800 (newest Forceware drivers)
Sound Card- Soundblaster Audigy 2zs
Networking - Wireless D-Link Card
Hard Drives - 1x 200gb Western Digital IDE, 1x 120gb Seagate IDE, 1x 250gb Western Digital SATA
Power Supply - 500watt ATX
CD-Rom- DVD-ROM RW drive
This should be mostly everything, I can and will run the memtest tonight at boot, but I do not believe that this is a hardware problem, I think its some kind of software problem.
Yes I did try running it in safe-mode though that didnt move to me much of anything, it ran kind of slow, kind of better, not really sure, I guess the laggyness that I'm experiencing was sort of gone, but it still seeed sort of laggy, but that might have been the usual "safe-mode" stuff that I was experiencing.
Disable all your non essential hw -
disconnect all your non essential drives from power and mobo.
Lets see if we can pin this down.
What make is your psu?
My PSU is kind of a generic 500 watt one. Athena Power silent engine is the only thing I can read off of it. Ill disconnect everything thing in just a minute.
I discconected everything, it's slightly different in the essence it takes programs forever to load, and the system startup is just a bit slower then it was before, however once programs start to run it seems to be a bit better in the fact that their nto so laggy, but i guess before they ran fairly decently too, it just took forever for them to start up and now its still like that. So what i can deduce is that its not a hardware related issue, it has to be something to do with the operating system.
Here it is:
Logfile of HijackThis v1.99.1
Scan saved at 7:57:27 PM, on 12/26/2005
Platform: Windows XP SP2 (WinNT 5.01.2600)
MSIE: Internet Explorer v6.00 SP2 (6.00.2900.2180)
Running processes:
C:\WINDOWS\System32\smss.exe
C:\WINDOWS\system32\winlogon.exe
C:\WINDOWS\system32\services.exe
C:\WINDOWS\system32\lsass.exe
C:\WINDOWS\system32\svchost.exe
C:\WINDOWS\System32\svchost.exe
C:\WINDOWS\Explorer.EXE
C:\WINDOWS\system32\spoolsv.exe
C:\WINDOWS\system32\CTHELPER.EXE
C:\Program Files\Saitek\Software\SaiSmart.exe
C:\Program Files\Saitek\Software\SaiMfd.exe
C:\Program Files\Adobe\Adobe Acrobat 7.0\Distillr\Acrotray.exe
C:\Program Files\CyberLink\PowerDVD\PDVDServ.exe
C:\Program Files\Java\jre1.5.0_04\bin\jusched.exe
C:\Program Files\F-Secure\Common\FSM32.EXE
C:\Program Files\Messenger\msmsgs.exe
C:\Program Files\MSN Messenger\msnmsgr.exe
C:\Program Files\Logitech\MouseWare\system\em_exec.exe
C:\PROGRA~1\F-Secure\BackWeb\7681197\Program\SERVIC~1.EXE
C:\Program Files\F-Secure\Anti-Virus\fsgk32st.exe
C:\Program Files\F-Secure\BackWeb\7681197\program\fsbwsys.exe
C:\Program Files\F-Secure\Anti-Virus\FSGK32.EXE
C:\Program Files\F-Secure\Common\FSMA32.EXE
C:\Program Files\F-Secure\Common\FSMB32.EXE
C:\Program Files\Alias\Maya7.0\docs\wrapper.exe
C:\Program Files\F-Secure\Anti-Virus\fssm32.exe
C:\Program Files\F-Secure\BackWeb\7681197\Program\F-Secure Automatic Update.exe
C:\Program Files\F-Secure\Common\FCH32.EXE
C:\WINDOWS\system32\nvsvc32.exe
C:\Program Files\Alcohol Soft\Alcohol 120\StarWind\StarWindService.exe
C:\Program Files\F-Secure\Common\FAMEH32.EXE
C:\Program Files\F-Secure\Anti-Virus\fsqh.exe
C:\Program Files\F-Secure\Anti-Virus\fsrw.exe
C:\Program Files\F-Secure\Anti-Virus\fsav32.exe
C:\Program Files\Alias\Maya7.0\docs\jre\bin\java.exe
C:\Program Files\F-Secure\FWES\Program\fsdfwd.exe
C:\Program Files\F-Secure\Common\FNRB32.EXE
C:\Program Files\F-Secure\Common\FIH32.EXE
C:\PROGRA~1\F-Secure\ANTI-S~1\fsaw.exe
C:\Program Files\F-Secure\FSGUI\fsguidll.exe
C:\DOCUME~1\Mike\LOCALS~1\Temp\Rar$EX00.718\HijackThis.exe
R1 - HKCU\Software\Microsoft\Windows\CurrentVersion\Internet Settings,ProxyOverride = localhost
O2 - BHO: AcroIEHlprObj Class - {06849E9F-C8D7-4D59-B87D-784B7D6BE0B3} - C:\Program Files\Adobe\Adobe Acrobat 7.0\ActiveX\AcroIEHelper.dll
O2 - BHO: AcroIEToolbarHelper Class - {AE7CD045-E861-484f-8273-0445EE161910} - C:\Program Files\Adobe\Adobe Acrobat 7.0\Acrobat\AcroIEFavClient.dll
O3 - Toolbar: Adobe PDF - {47833539-D0C5-4125-9FA8-0819E2EAAC93} - C:\Program Files\Adobe\Adobe Acrobat 7.0\Acrobat\AcroIEFavClient.dll
O4 - HKLM\..\Run: [NeroCheck] C:\WINDOWS\system32\NeroCheck.exe
O4 - HKLM\..\Run: [Logitech Utility] Logi_MwX.Exe
O4 - HKLM\..\Run: [CTHelper] CTHELPER.EXE
O4 - HKLM\..\Run: [SBDrvDet] C:\Program Files\Creative\SB Drive Det\SBDrvDet.exe /r
O4 - HKLM\..\Run: [UpdReg] C:\WINDOWS\UpdReg.EXE
O4 - HKLM\..\Run: [NvCplDaemon] RUNDLL32.EXE C:\WINDOWS\system32\NvCpl.dll,NvStartup
O4 - HKLM\..\Run: [nwiz] nwiz.exe /install
O4 - HKLM\..\Run: [Profiler] C:\Program Files\Saitek\Software\Profiler.exe
O4 - HKLM\..\Run: [SaiSmart] C:\Program Files\Saitek\Software\SaiSmart.exe
O4 - HKLM\..\Run: [SaiMfd] C:\Program Files\Saitek\Software\SaiMfd.exe
O4 - HKLM\..\Run: [Adobe Version Cue CS2] "C:\Program Files\Adobe\Adobe Version Cue CS2\ControlPanel\VersionCueCS2Tray.exe"
O4 - HKLM\..\Run: [Acrobat Assistant 7.0] "C:\Program Files\Adobe\Adobe Acrobat 7.0\Distillr\Acrotray.exe"
O4 - HKLM\..\Run: [RemoteControl] "C:\Program Files\CyberLink\PowerDVD\PDVDServ.exe"
O4 - HKLM\..\Run: [iTunesHelper] "C:\Program Files\iTunes\iTunesHelper.exe"
O4 - HKLM\..\Run: [QuickTime Task] "C:\Program Files\QuickTime\qttask.exe" -atboottime
O4 - HKLM\..\Run: [SunJavaUpdateSched] C:\Program Files\Java\jre1.5.0_04\bin\jusched.exe
O4 - HKLM\..\Run: [EasyPHP] "C:\Program Files\EasyPHP1-7\easyphp.exe"
O4 - HKLM\..\Run: [Samsung Common SM] "C:\WINDOWS\Samsung\ComSMMgr\ssmmgr.exe" /autorun
O4 - HKLM\..\Run: [NvMediaCenter] RUNDLL32.EXE C:\WINDOWS\system32\NvMcTray.dll,NvTaskbarInit
O4 - HKLM\..\Run: [F-Secure Manager] "C:\Program Files\F-Secure\Common\FSM32.EXE" /splash
O4 - HKLM\..\Run: [F-Secure TNB] "C:\Program Files\F-Secure\TNB\TNBUtil.exe" /CHECKALL /WAITFORSW
O4 - HKCU\..\Run: [MSMSGS] "C:\Program Files\Messenger\msmsgs.exe" /background
O4 - HKCU\..\Run: [msnmsgr] "C:\Program Files\MSN Messenger\msnmsgr.exe" /background
O4 - HKCU\..\Run: [URLy Warning] "C:\Program Files\URLy Warning\URLyWarning.exe" -quiet
O4 - HKCU\..\Run: [FreeRAM XP] "C:\Program Files\YourWare Solutions\FreeRAM XP Pro\FreeRAM XP Pro.exe" -win
O4 - Startup: WinMySQLadmin.lnk = C:\mysql\bin\winmysqladmin.exe
O4 - Global Startup: F-Secure Automatic Update.lnk = C:\Program Files\F-Secure\BackWeb\7681197\program\F-Secure Automatic Update.exe
O8 - Extra context menu item: &Block this popup - C:\Program Files\F-Secure\Anti-Spyware\blockpopups.htm
O8 - Extra context menu item: Convert link target to Adobe PDF - res://C:\Program Files\Adobe\Adobe Acrobat 7.0\Acrobat\AcroIEFavClient.dll/AcroIECapture.html
O8 - Extra context menu item: Convert link target to existing PDF - res://C:\Program Files\Adobe\Adobe Acrobat 7.0\Acrobat\AcroIEFavClient.dll/AcroIEAppend.html
O8 - Extra context menu item: Convert selected links to Adobe PDF - res://C:\Program Files\Adobe\Adobe Acrobat 7.0\Acrobat\AcroIEFavClient.dll/AcroIECaptureSelLinks.html
O8 - Extra context menu item: Convert selected links to existing PDF - res://C:\Program Files\Adobe\Adobe Acrobat 7.0\Acrobat\AcroIEFavClient.dll/AcroIEAppendSelLinks.html
O8 - Extra context menu item: Convert selection to Adobe PDF - res://C:\Program Files\Adobe\Adobe Acrobat 7.0\Acrobat\AcroIEFavClient.dll/AcroIECapture.html
O8 - Extra context menu item: Convert selection to existing PDF - res://C:\Program Files\Adobe\Adobe Acrobat 7.0\Acrobat\AcroIEFavClient.dll/AcroIEAppend.html
O8 - Extra context menu item: Convert to Adobe PDF - res://C:\Program Files\Adobe\Adobe Acrobat 7.0\Acrobat\AcroIEFavClient.dll/AcroIECapture.html
O8 - Extra context menu item: Convert to existing PDF - res://C:\Program Files\Adobe\Adobe Acrobat 7.0\Acrobat\AcroIEFavClient.dll/AcroIEAppend.html
O8 - Extra context menu item: Download all by Free Download Manager - file://C:\Program Files\Free Download Manager\dlall.htm
O8 - Extra context menu item: Download by Free Download Manager - file://C:\Program Files\Free Download Manager\dllink.htm
O8 - Extra context menu item: Download selected by Free Download Manager - file://C:\Program Files\Free Download Manager\dlselected.htm
O8 - Extra context menu item: Download web site by Free Download Manager - file://C:\Program Files\Free Download Manager\dlpage.htm
O9 - Extra button: (no name) - {08B0E5C0-4FCB-11CF-AAA5-00401C608501} - C:\Program Files\Java\jre1.5.0_04\bin\npjpi150_04.dll
O9 - Extra 'Tools' menuitem: Sun Java Console - {08B0E5C0-4FCB-11CF-AAA5-00401C608501} - C:\Program Files\Java\jre1.5.0_04\bin\npjpi150_04.dll
O9 - Extra button: IE Shield - {300DB664-75B5-47c0-8B45-A44ACCF73C00} - C:\Program Files\F-Secure\Anti-Spyware\ieshield.dll
O9 - Extra 'Tools' menuitem: IE Shield... - {300DB664-75B5-47c0-8B45-A44ACCF73C00} - C:\Program Files\F-Secure\Anti-Spyware\ieshield.dll
O9 - Extra button: Yahoo! Messenger - {E5D12C4E-7B4F-11D3-B5C9-0050045C3C96} - C:\PROGRA~1\Yahoo!\MESSEN~1\YPager.exe
O9 - Extra 'Tools' menuitem: Yahoo! Messenger - {E5D12C4E-7B4F-11D3-B5C9-0050045C3C96} - C:\PROGRA~1\Yahoo!\MESSEN~1\YPager.exe
O9 - Extra button: Messenger - {FB5F1910-F110-11d2-BB9E-00C04F795683} - C:\Program Files\Messenger\msmsgs.exe
O9 - Extra 'Tools' menuitem: Windows Messenger - {FB5F1910-F110-11d2-BB9E-00C04F795683} - C:\Program Files\Messenger\msmsgs.exe
O10 - Unknown file in Winsock LSP: c:\program files\f-secure\fsps\program\fslsp.dll
O10 - Broken Internet access because of LSP provider 'winsflt.dll' missing
O15 - Trusted Zone: http://*.://postpublisher.net
O16 - DPF: {6414512B-B978-451D-A0D8-FCFDF33E833C} (WUWebControl Class) - http://update.microsoft.com/windowsupda...86/client/wuweb_site.cab?1126613058937
O16 - DPF: {BE833F39-1E0C-468C-BA70-25AAEE55775E} (System Requirements Lab) - http://www.systemrequirementslab.com/sysreqlab.cab
O18 - Protocol: msnim - {828030A1-22C1-4009-854F-8E305202313F} - "C:\PROGRA~1\MSNMES~1\msgrapp.dll" (file missing)
O23 - Service: Adobe LM Service - Adobe Systems - C:\Program Files\Common Files\Adobe Systems Shared\Service\Adobelmsvc.exe
O23 - Service: Adobe Version Cue CS2 - Unknown owner - C:\Program Files\Adobe\Adobe Version Cue CS2\bin\VersionCueCS2.exe" -win32service (file missing)
O23 - Service: F-Secure 2006 (BackWeb Plug-in - 4476822) - Unknown owner - C:\PROGRA~1\F-Secure\BackWeb\4476822\Program\SERVIC~1.EXE (file missing)
O23 - Service: F-Secure Automatic Update (BackWeb Plug-in - 7681197) - F-Secure Automatic Update - C:\PROGRA~1\F-Secure\BackWeb\7681197\Program\SERVIC~1.EXE
O23 - Service: FSGKHS (F-Secure Gatekeeper Handler Starter) - F-Secure Corp. - C:\Program Files\F-Secure\Anti-Virus\fsgk32st.exe
O23 - Service: F-Secure Network Request Broker - F-Secure Corporation - C:\Program Files\F-Secure\Common\FNRB32.EXE
O23 - Service: fsbwsys - F-Secure Corp. - C:\Program Files\F-Secure\BackWeb\7681197\program\fsbwsys.exe
O23 - Service: F-Secure Anti-Virus Firewall Daemon (FSDFWD) - F-Secure Corporation - C:\Program Files\F-Secure\FWES\Program\fsdfwd.exe
O23 - Service: F-Secure HTTP Server (fshttps) - Unknown owner - C:\Program Files\F-Secure\FSPC\fshttps\fshttps.exe (file missing)
O23 - Service: F-Secure Management Agent (FSMA) - F-Secure Corporation - C:\Program Files\F-Secure\Common\FSMA32.EXE
O23 - Service: InstallDriver Table Manager (IDriverT) - Macrovision Corporation - C:\Program Files\Common Files\InstallShield\Driver\11\Intel 32\IDriverT.exe
O23 - Service: iPodService - Apple Computer, Inc. - C:\Program Files\iPod\bin\iPodService.exe
O23 - Service: Maya 7.0 Documentation Server (maya70docserver) - Unknown owner - C:\Program Files\Alias\Maya7.0\docs\wrapper.exe" -s "C:\Program Files\Alias\Maya7.0\docs\Wrapper.conf (file missing)
O23 - Service: NVIDIA Display Driver Service (NVSvc) - NVIDIA Corporation - C:\WINDOWS\system32\nvsvc32.exe
O23 - Service: PHPGeekUtil - Unknown owner - c:\apache\APACHE.EXE" --ntservice (file missing)
O23 - Service: StarWind iSCSI Service (StarWindService) - Rocket Division Software - C:\Program Files\Alcohol Soft\Alcohol 120\StarWind\StarWindService.exe
Here is a startup process list too
StartupList report, 12/26/2005, 8:21:37 PM
StartupList version: 1.52
Started from : C:\DOCUME~1\Mike\LOCALS~1\Temp\Rar$EX00.579\StartupList.EXE
Detected: Windows XP SP2 (WinNT 5.01.2600)
Detected: Internet Explorer v6.00 SP2 (6.00.2900.2180)
* Using default options
Running processes:
C:\Program Files\Mozilla Firefox\firefox.exe
C:\DOCUME~1\Mike\LOCALS~1\Temp\Rar$EX00.985\procexp.exe
C:\Program Files\WinRAR\WinRAR.exe
C:\DOCUME~1\Mike\LOCALS~1\Temp\Rar$EX00.579\StartupList.exe
Listing of startup folders:
Shell folders Startup:
[C:\Documents and Settings\Mike\Start Menu\Programs\Startup]
Shell folders Common Startup:
[C:\Documents and Settings\All Users.WINDOWS\Start Menu\Programs\Startup]
Checking Windows NT UserInit:
[HKLM\Software\Microsoft\Windows NT\CurrentVersion\Winlogon]
UserInit = C:\WINDOWS\system32\userinit.exe,
Autorun entries from Registry:
HKLM\Software\Microsoft\Windows\CurrentVersion\Run
NeroCheck = C:\WINDOWS\system32\NeroCheck.exe
Logitech Utility = Logi_MwX.Exe
CTHelper = CTHELPER.EXE
SBDrvDet = C:\Program Files\Creative\SB Drive Det\SBDrvDet.exe /r
UpdReg = C:\WINDOWS\UpdReg.EXE
NvCplDaemon = RUNDLL32.EXE C:\WINDOWS\system32\NvCpl.dll,NvStartup
nwiz = nwiz.exe /install
Profiler = C:\Program Files\Saitek\Software\Profiler.exe
SaiSmart = C:\Program Files\Saitek\Software\SaiSmart.exe
SaiMfd = C:\Program Files\Saitek\Software\SaiMfd.exe
Adobe Version Cue CS2 = "C:\Program Files\Adobe\Adobe Version Cue CS2\ControlPanel\VersionCueCS2Tray.exe"
Acrobat Assistant 7.0 = "C:\Program Files\Adobe\Adobe Acrobat 7.0\Distillr\Acrotray.exe"
RemoteControl = "C:\Program Files\CyberLink\PowerDVD\PDVDServ.exe"
iTunesHelper = "C:\Program Files\iTunes\iTunesHelper.exe"
QuickTime Task = "C:\Program Files\QuickTime\qttask.exe" -atboottime
SunJavaUpdateSched = C:\Program Files\Java\jre1.5.0_04\bin\jusched.exe
EasyPHP = "C:\Program Files\EasyPHP1-7\easyphp.exe"
Samsung Common SM = "C:\WINDOWS\Samsung\ComSMMgr\ssmmgr.exe" /autorun
NvMediaCenter = RUNDLL32.EXE C:\WINDOWS\system32\NvMcTray.dll,NvTaskbarInit
F-Secure Manager = "C:\Program Files\F-Secure\Common\FSM32.EXE" /splash
F-Secure TNB = "C:\Program Files\F-Secure\TNB\TNBUtil.exe" /CHECKALL /WAITFORSW
HKCU\Software\Microsoft\Windows\CurrentVersion\Run
MSMSGS = "C:\Program Files\Messenger\msmsgs.exe" /background
msnmsgr = "C:\Program Files\MSN Messenger\msnmsgr.exe" /background
URLy Warning = "C:\Program Files\URLy Warning\URLyWarning.exe" -quiet
FreeRAM XP = "C:\Program Files\YourWare Solutions\FreeRAM XP Pro\FreeRAM XP Pro.exe" -win
Shell & screensaver key from C:\WINDOWS\SYSTEM.INI:
Shell=*INI section not found*
SCRNSAVE.EXE=*INI section not found*
drivers=*INI section not found*
Shell & screensaver key from Registry:
Shell=Explorer.exe
SCRNSAVE.EXE=C:\WINDOWS\System32\logon.scr
drivers=*Registry value not found*
Policies Shell key:
HKCU\..\Policies: Shell=*Registry key not found*
HKLM\..\Policies: Shell=*Registry value not found*
Enumerating Browser Helper Objects:
(no name) - C:\Program Files\Adobe\Adobe Acrobat 7.0\ActiveX\AcroIEHelper.dll - {06849E9F-C8D7-4D59-B87D-784B7D6BE0B3}
(no name) - C:\Program Files\Adobe\Adobe Acrobat 7.0\Acrobat\AcroIEFavClient.dll - {AE7CD045-E861-484f-8273-0445EE161910}
Enumerating Download Program Files:
[WUWebControl Class]
InProcServer32 = C:\WINDOWS\System32\wuweb.dll
CODEBASE = http://update.microsoft.com/windowsupda...86/client/wuweb_site.cab?1126613058937
[System Requirements Lab Class]
InProcServer32 = C:\WINDOWS\Downloaded Program Files\sysreqlab.dll
CODEBASE = http://www.systemrequirementslab.com/sysreqlab.cab
OSD = C:\WINDOWS\Downloaded Program Files\sysreqlab.osd
[Shockwave Flash Object]
InProcServer32 = C:\WINDOWS\system32\Macromed\Flash\Flash8.ocx
CODEBASE = http://fpdownload.macromedia.com/pub/shockwave/cabs/flash/swflash.cab
Enumerating Winsock LSP files:
Protocol #16: winsflt.dll (file MISSING)
Protocol #17: winsflt.dll (file MISSING)
Protocol #18: winsflt.dll (file MISSING)
Protocol #19: winsflt.dll (file MISSING)
Protocol #20: winsflt.dll (file MISSING)
Protocol #38: winsflt.dll (file MISSING)
Enumerating ShellServiceObjectDelayLoad items:
PostBootReminder: C:\WINDOWS\system32\SHELL32.dll
CDBurn: C:\WINDOWS\system32\SHELL32.dll
WebCheck: C:\WINDOWS\System32\webcheck.dll
SysTray: C:\WINDOWS\System32\stobject.dll
End of report, 7,747 bytes
Report generated in 0.797 seconds
Command line options:
/verbose - to add additional info on each section
/complete - to include empty sections and unsuspicious data
/full - to include several rarely-important sections
/force9x - to include Win9x-only startups even if running on WinNT
/forcent - to include WinNT-only startups even if running on Win9x
/forceall - to include all Win9x and WinNT startups, regardless of platform
/history - to list version history only
WHAT is THIS? Do you know?
On the whole looks ok apart from above. Can you disable your antivirus automatic startup, and reboot.
Go through msconfig, and untick all non essential stuff. (MSN/Adobe stuff etc)
When did you install the RAM manager sw?
Try not running that at boot.
Restart.
Any different
