I cannot figure out why my network wireless blows so hard.
My main dsl modem/router is a Netgear DGN2000(wireless n capable). I used to have this bridged to a WRT54G running DDWRT. For some reason wireless transfer between my laptop (envy 15) and my desktop or htpc plugged into the wrt54g was literally almost nothing. It would bounce between 50/100kbs but in reality nothing was happening. The internet was bridged just fine though so I just lived with that for a while. Transfering files between my PC and HTPC (both plugged into the WRT54G) would be about 90MB/s.
I have super crappy qwest dsl 1.5down so I max out at 155KB/s on download speeds anyway. So my main beef has nothing to do with internet speeds, just my internal network interaction.
I decided my WRT54G was dying and just replaced it with an Asus RT-N16. I installed tomato on it and got the client bridging working just fine. Now while there is a significant improvement, I am not getting the network transfer speeds I expect. If I force b/g mode I hover between 500Kb/s and 900 on file transfers. Well at least it works now, but shouldn't I expect 1.5MB+ on b/g alone?
Now if I set wireless n the speeds don't change at all. I am aware of setting WPA2/AES and making sure no b/g devices are connected.
I'm guessing my problem has something to do with the way client bridging works. Maybe somebody can explain it to me. Upstairs is where the DGN2000 is. I am downstairs with my laptop sitting right next to the RT-N16 bridge. I was under the impression that the bridge also acted as a rebroadcaster of the signal, but now I'm thinking that's not the case. So my laptop is connecting to the wireless signal upstairs, then being sent back downstairs to my bridge.
I don't get why this would matter though because my modem/router upstairs is set to wireless n as well. Any ideas?
<edit>
I should mention I have it on channel 6 and I live in the boonies and there isn't any interference from other wireless networks.
<edit>
