Slow win10 network speed. Disabling “Large Send Offload (LSO)”
IGBT
17,976
141
Reactions: PliotronX
PliotronX
8,883
107
I had to disable this on the Hyper-V nic (inside the guest) to fix a problem with load balanced federation VMs that mimicked Memory Pressure Protection issues killing TCP connections every 5-8 weeks. I don't know why LSO is on by default. Its one of those features that should only be enabled when the hardware and software supports it correctly. As for slowness, I haven't seen it change either way but there are tons of anecdotes about it hurting performance too.
[DHT]Osiris
17,429
16,723
Any thoughts on this tweak??
Large Send Offload is a technique of improving network performance while at the same time reducing CPU overhead. Apparently it does not work very well, so it was suggested to disable it. If you would like to know about LSO, check this MSDN article from 2001 (Task Offload (NDIS 5.1) (Windows Drivers)).
https://www.tenforums.com/network-sharing/42543-lan-network-slow-speeds.html
Most hardware nowadays supports LSO and LRO just fine, but there's still a few finicky NICs that get squirrely with it. In addition I've run in to some with certain workload issues, like rapidly receiving extremely large packets for offloading (think SAN array flooding a NIC with 32MB packets).
Realistically, if there's no issue with your NIC and they're relatively modern, they should run LSO/LRO fine. You can disable it to see if speed/reliability improve, but don't expect it to work miracles.
