In which case you can breathe a certain sigh of relief. Look here's what I think you should do ~SO....... I was given an answer on another thread in here about trim support for raid. According to this person, trim is NOT supported with RAID 0 on an amd board. So im gonna quit looking for awhile. so what i did is change everything back to ACHI and I created a spanned volume in windows disk manager. I cant manually trim the drive but i ran Trimcheck 0.7 and it says that trim appears to be working!!! i also have a 4gb cache set up for the drive and i get up to 4gb/s read speed (I have the cache set up for read only). I dont know if this is wise, but its what ive been playing around with lately.
- Put 2 SSD's in RAID0, make two RAID0 arrays. Now Use Primocache & allocate as much memory as you possibly can for L1 cache, then use the second RAID0 array as L2 cache for your system drive ~ which I'm assuming is going be the two 850's in RAID0. Also get a UPS because whenever you're using a cache buffer you're bound to have a (potentially critical) data loss scenario, so better be safe than sorry. Just an FYI don't disable the pagefile whenever you're using any caching software.
- Use one of the 850's as a single system boot drive, then use RAPID & again allocate as much RAM as possible for caching. Use the rest of the three drives in RAID0 & move your pagefile, temp (appdata/local & windows) folders over to that array so that their(RAID0) performance isn't totally wasted.
