Slow SATA hard drive performance... help please? :(
Bagheera
310
Hey guys...
My 200GB Maxtor DiamondMax 9 HDD (ATA-133) just died recently; it was still under warranty so I got a replacement hard drive from Maxtor. But then I thought, what the heck? May be I should look for something more durable, since I leave my system on 24/7. So I bought a Maxtor MaxLine III 250 GB SATA-150 HDD from NewEgg; it comes with 5-year warranty and is designed for 1 million hours of continuous operation.
So I just got my MaxLine III today, hooked it up to the SATA port, installed WinXP with the Third Party Raid driver; WinXP booted up fine...
Then as I began to install all the softwares I noticed something strange - the hard drive seems very slow. Or rather, perhaps the SATA control chip is not handling the bandwidth correctly; I am not sure what the problem is... but I can hardly multi-task. The system responds very slowly/chokes whenever there are more then two programs trying to access the hard drive at the same time; I swear this is at least 40% slower than my IDE hard drive...
Would anyone have had a similar experience with SATA hard drives? Mobo: Gigabyte GA-N400 Pro 2 + Silicon Image 3512 SATA Raid (onboard chip) + Maxtor MaxLine III 250GB
Thanks in advance to those who reply!
INM8
274
I dont know whats wrong with your HDD, but id be carefull with it. It seems like alot of the maxline 3's have been dieing lately. Id make sure you have a backup of all your important data just incase.
Is the SI controller the only sata controller on your mobo? It could also be a problem with the sata controllers drivers. Have you got the latest drivers?
Sorry i cant be of much help, but thats all i can think of. I havent ever experienced a problem like that with a drive, but i would enable SMART and keep a close eye on the drive, just incase it decides to die on you.
Bagheera
310
Umm well this MaxLine III just got to me today, it's brand new... if I am that unlucky as to get a brand new drive that's about to die... err, oh well.
And yes the chipset drivers are installed... :/
Bagheera
310
Just a side note, the peak transfer rate seems to be normal... file transfers between the MaxLine III and other devices are very fast; but it kind of chokes when multiple access to the HDD is requested... humm...
Jiggz
4,329
I'm using the same mobo and love it so much for its stability. But now I heard about your experience, maybe I should just stay with my RAID 0 ATA hdd.
Mem
21,476
13
I'm using a Maxtor Maxline III HD too(300GB) but it is working great in my Epox 9NPA+ Ultra board,have you tried Maxtor diagnostic utility on their website you can download?..
I would also change HD cable and run Memtest86+ ,start ruling out other things too.
