Hello,
I just got a new PC and the setup is:
Athlon XP 1.53 (1800)
Micron 256MB PC2100 DDR
ECS K7S5A Motherboard
Gainward GeForce 3 Ti200 (Latest Drivers, 28.32)
GameSurround MuseXL
Windows 2000 Clean Install and Updated
From the performance numbers I see around the web, my PC seems to be running a lot slower than other PCs out there. For example, on Quake 3 v1.31, I *only* get 133fps at 1024x768x32. While on Anand, AMDMB.com, and a ton of other sites are getting 182fps! I'm 50fps slower! I know our two systems aren't completely identical, but I don't think they should be 50fps apart.
Also, I'm only getting 6150 3Dmarks with the 3DMark 2001 compared to the 7000+ I'm seeing for similarly equipped systems. I just installed Win2k, updated it with the latest service packs, installed DirectX8.1, installed new vid. card drivers, etc. etc. etc. What could possibly be the problem? Has this happened to anyone else?
-kabo
GameSurround MuseXL
-kabo
