Slow/jerky wireless mouse movement when transfer large files over wired lan
pollardhimself
281
Got a weird issue Slow/jerky wireless mouse movement when transferring large files over wired lan? Using windows 7 on a dell e6500 in a docking station, tried moving the usb transceiver. any have the same issue
elconejito
607
www.harvsworld.com
unrelated to large transfers, my blackberry causes intermittent slow/jerky movement if it's on my desk. I only mention it because it took me a while to figure out it was my phone that caused the issue.
heymrdj
3,999
63
Yeah I have this same issue. Presumedly it's the fact the RF receiver in my Logitech MX is 2.4Ghz, just like the Wireless G signal going from my laptop. The laptop obviously puts out a much stronger signal which causes alot of noise to the mouse.
KingGheedora
3,248
To the OP, and hrmrdj, if your router supports it, try changing the network to 5GHz frequency. That might help avoid the interference you're seeing.
corkyg
Elite Member | Peripherals
27,370
239
Wired or wireless- it indicates spurious emission interference (RFI). Is your network cable well shielded? Can you try a different cable? It could also be coming from the docking station. Try it without that.
vshah
19,003
24
check your cpu usage when transferring large files. i've seen crappy nics cause large spikes before.
elconejito
607
www.harvsworld.com
if you have another wireless mouse to test with, try that and see if it still does the same. If so, then it's definitely something in your environment. cell phone, cordless phone, microwave, your neighbor's wireless mouse, etc.
If not, then you may have a defective mouse.
OR, you might have something on your desk or under mouse that is interfering with the tracking laser like a piece of lint/dust.
pollardhimself
281
Im at work, and its only when transferring larges file over the wired lan connection
vshah
19,003
24
Looks like this is what it is, anything i can do about it its a laptop
its a intel(R) 82567LM Gigabit Network Connection
intel NICs are usually far from crappy. make sure you have the latest drivers, other than that not sure...
0roo0roo
64,795
84
easy to test, just use the wireless on another pc with nic and transfer files and see if it jerks.
if it doesn't, your drivers or something funky is going on with the first system.
pollardhimself
281
It was malwarebytes website blocking feature also was choking network file transfer speeds down to 50Mb. It cause the mouse to mess up
0roo0roo
64,795
84
no, more simply bring the mouse to another computer, if it works fine on that one, its a defective computer;)
