Hi Guys
I just put together a new K6-2 550 System for the family to use at home (dirt cheap). Anyway, I'm concerned about the speed of the Hard Disk - it's a Fujitsu MPE3136AT. Under Sandra it shows up as ~4000, which is a third of what the IBM 13.5gb 22GXP gets on my machine - Celeron 550 on a ZX Chipset motherboard. This is with all the ALI Drivers installed, at UDMA66 with DMA enabled. Should I splash out on a Promise card for the machine to impove the HD performance, assuming it's the motherboard chipset that's slow - or is it just the drive (it was cheap too...but it's big and reliable).
all comments appreciated
cheers
tweakr
cheers
tweakr
