Hi all,
I have a Asus A8N-SLI.
everything is at stock setting.
When i connect the cpu fan onto the motherboard cpu fan plug, the speed from Asus Probe say it is 1500rpm and if i use a convertor, connect it to a harddrive (4pin) power connector, it rated 5000rpm.
Can i change the speed of the CPU fan in the motherboard?
Also, there is a "chasis fan" plug for case fan , it is also a 3 pin, i put the 12mm coolermaster fan onto it, it says 1500rpm too, but if i connected with big 4 pin, it is 5000rpm.
Can i also change that speed from the motherboard or bios?
Thanks
Thanks
