SlotA mobo modding
CTho9305
dunno if this would be better in another forum, but anyway:
All slotA mobos are 100 FSB. but, some of them (k7v) do 133 just fine, except you're stuck with a PCI of 44. I looked at the pins on the PLL and was wondering if there was some way to get 133/33 out of it by modding resistors near it or something.
Or is the poorly documented/translated Turbo.PLL mod required?
<< some of them (k7v) do 133 just fine >>
your K7V must be on steroids because mine doesn't boot over 105 FSB, and I've never heard of any doing even close to 133.
sorry, need to clarify. I can't boot over 112 normally. but if you set the dipswitches to 1101 (1100 is 100/33) it should boot just fine (assuming pc133 ram and a cpu that either OCs well, or has its multiplier lowered). mine doesn't work on X.5 multipliers, so i just used X.0 (5 or 6)
this is all the settings. only a few will boot for me, and only 2 are stable (100/33 and 133/44)
edit: double post, so i added the link 😉
