Slot fan for 6600GT?
Ashurbanapli
So I got a replacement Gigabyte 6600GT (previous one had extremely high core temps) and this time around I want to keep it very cool. This particular model of 6600GT has a giant piped pair of HS, but no HSF.
Looking for recommendations on a slot fan, since I don't have a door-mounted case fan that blows into the PCI-E area, and I don't want a Zalman or similar that requires me to disassemble the extant HS (card is under warranty!)
Thanks,
-Ashur
they're around. newegg will be the easiest place to find them but nearly everyoine carries them and some at better pricing.
the only one i used and will probably get again is the dynatron. i think its about $5. but a bunch are the same and just branded by different makers. theres another i may get which has 2 fans, maybe its 3 so i can get some multi directional action going.
if noise is important to you you'll want to hook them up to a fan controller though. most are fairly loud.
I have the Gigabyte 6800 heatpipe model and adding a slot cooler 2 slots below it did drop the temp 10+ degrees C in gaming (didn't make any real difference in 2D).
The no-name cooler I had in my parts bin wouldn't fit in the PCI slot directly below the 6800, but maybe some other model would.
Newegg sells several different models, $5 and up.
