I am not sure but I *think* disabling CPU Internal Thermal Control will shut off the need for a sensor feed.
I did look for awhile because this old fart did spot it about 6 months ago. A small encased circuit that plugs into the fan wiring to the CPU fan header that will multiply the tach signal. IIRC, it doubles the signal, so 750rpm would be sensed as 1500rpm.
It was not a controller with a built in alarm but a multiplier.
You might PM one of the WCed guys, like HardWarrior, into your thread because they have little need for the tach signal.
...Galvanized
