I am looking to buy my sister and her husband a computer, to replace their old Pentium 100 system which has given them problems from the start (weird errors and reboots, malfunctioning hardware, etc.) and has gotten too slow even for the applications they run. They do not use it to play games, and the machine is really gonna be used as a workstation (think of at it as a deluxe typewriter), but it would be nice if it could play DVDs without having to install a hardware DVD decoder. I'm interested in getting something in the 500MHz - 700MHz range (I assume that should be enough, right?), but without spending hundreds of dollars on the mainboard/CPU/RAM combo alone. So what I'm looking for is yesterday's technology, but the kind that isn't going to be outdated tomorrow. (Basically, it should support PC-133 RAM, ATA66, and that kind of stuff -- I don't expect ATA133, RAID, PC-2700 DDR, etc. etc.)
Anyway... I think the kind of CPU I am looking for is either an Intel P-III or AMD Athlon (early Socket A type). But I am not at all familiar with Intel processors anymore (last one I used was a P60...), and I'm not sure what I should be looking for. I read things such as 600E, 600EB, etc. etc. and I haven't a clue what is compatible anymore. (I know it's got to do with .18 micron and bus speeds and stuff, but I'm not sure if or how these are compatible.) Also, I've noticed that there are Slot 1 P-IIIs, but also FC-PGA P-IIIs in the same range. It would be nice if I could do a CPU upgrade in 12 - 18 months' time or so, and not have to replace the mainboard and RAM at the same time, so that's why I thought I should go for FC-PGA processors if I choose Intel. But while surfing the Internet, I found that there are converters that allow you to run FC-PGA processors on Slot 1 mainboards. Are these an alternative to the more expensive FC-PGA (Socket 370?) mainboards, or do you really get what you pay for and (say I want to upgrade to a 1GHz P-III later) will only give you so much more?
Taking into account the cost (money's an issue, but I am willing to pay a bit more if it means it's got more "CPU headroom"), should I be looking for Slot 1 mainboards, or is it worth investing more money in a reasonably up-to-date mainboard? I know P-IIIs are not gonna be around much longer, but if spending $30 more today on a FC-PGA mainboard allows me to upgrade to a 1GHz P-III or whatever without too much trouble (basically I just wanna replace the CPU), that's worth it to me. (I wanna save as much money as possible, but not at every cost.
) Any suggestions for an Intel CPU/mainboard that holds promise?
Last but not least, considering P-III mainboards... are there chipsets I should make sure to avoid? (I've seen a few cheap ones with i820 or i810 chipsets and such, but exactly because they are so cheap I'm worried there are problems with them.)
