Hi,
I've just installed a Thermalright SLK900U and a Panaflo 92mm fan on top of it. The combination is working fantastic, sound is very quiet and the cooling is significantly better than the stock Intel HSF.
I had a 3 pin header on the end of the Panaflo fan, and plugged that into the motherboard where the Intel fan plugged in. With the Intel unit I could monitor fan speeds, but now with the Panaflo installed I don't see that information anymore, it reports that no fan is connected. The fan is definitely working, it's spinning all the time.
What do I do to be able to monitor the fan speeds again? Any detriment to NOT being able too see that info? The fan speed should still increase with CPU temps right?
seismik
seismik
