er anyway, it might be possible in a ghetto-stylee. If i can stick a 80mm on my Taisol GCK760 (designed for 60mm's), then you can probably manage it. Might require tie-rips, and have like 3/4 of the airflow wasted over the side, but technically it will "take" a 92mm fan 😉
maybe better off with a SK-7, which is designed for 60 to 80mm fans, or the SLK-700 with a 74mm TMD fan (which Thermalright and dans data seem impressed with, on the SLK-700). Then of course there's SLK-800 which officially supports 80mm but someone said can do 92mm, or the SLK-900 which officially does support 94mm.
K?
I should buy one of these things myself sometime 😛
