- Jan 3, 2001
- 4,194
- 574
- 126
I just can't figure why an SLK-800 is running hotter than a Volcano 11 on the exact same system. What am I doing differently or wrong?
I started with a Volcano 11+ which comes with a Smart Fan II. It has a nice controller you mount in a PCI slot and then you can turn it up and down when you need to. Temps were 31 case, 34 CPU. Running F@H temps were 34 and 38.
Then I got an SLK-800 and an original Smart Fan. I ordered a SF II and an SK-7 but they were out of both and so we made a deal.
I take off the Volcano, clean everything, apply AS3, mount the SLK-800 backwards, fix it, and then first try the SF2 from the Volcano. Now the fanbus doesn't work, and I notice my temps slowly rising. However, the fan is running full blast.
I shut it down, take everything apart, clean again, apply less AS3 this time (had too much at first I think) and this time mount the original Smart Fan, plugging the yellow wire into the mobo at the "cpu fan" plug and use a 3 to 4 pin adapter to plug the fan into the PSU. Is this correct? TINFM (there is no f***ing manual).
Case 32 CPU 40
Any ideas what I am doing wrong? 40C isn't the end of the world, but my cpu temp should have dropped, not gone up.
Case 32 CPU 40
