I am buying some things soon. Some things were damaged in a storm and to replace the motherboard and CPU i'm buying a 2800+ Athlon XP (Barton) on an Abit NF7-S (which will most likely be Rev 2.0). My CPU wasn't damaged but I am getting a new one anyways. Should I use the SLK-800A and my existing 80mm fan from my Volcano 9? Would it make a difference if I bought a Panaflo 80mm fan?
I might get the Smart Fan II if that isn't the same thing. I would really like the Thermal capabilities again...they were very nice. If someone knows a good 80mm fan out there where it fits the speed adjuster on a 3.5" bay, please let me know!
I am under the impression that this SLK-800A is the best choice, but I *think* it doesn't include a manual for install and I heard it was a tricky installation. Is this true?
