Slipstreaming SP2 into XP PRO CORP
If you are using the corporate version you should talk to the administrator. They'll be able to hook you up.
Or, if it isn't a corporate version, try activating again or whatever. It's really simple.
I've slipsreamed SP2 (2180) with a corp version of XP without any problems.
It installed correctly and I didn't receive any activation errors.
Same here,no problems at all.
I'm gonna go right ahead and fly the Jolly Roger here.
1) It's "Volume License" not "Corporate Edition"
2) SP2 has anti-warez measures for bad keys
3) My SP2 slipstream on the test box has no issues (I'm sticking to SP1 on the main rig until I finish Doom 3. 😛 )
- M4H
