Slipstreaming problems...
Fullmetal Chocobo
Moderator<br>Distributed Computing
Moderator
May 13, 2003
13,704
7
I get it when I install programs and updates sometimes. I have to put in the slipstreamed CD, and then it continues on it's merry way. Just wondering if anyone else is experiencing that.
Tas.
RedCOMET
2,836
I'm having that problem with my NLite xp sp2 slipstreamed cd.
I think in my next build of the cd, i might disable the wep.
My cd was created back in april, so, i haven't done much to try to resolve the issue.
Fullmetal Chocobo
Moderator
May 13, 2003
13,704
7
Hmmmm. I think it has something to do with nLite then... That is what I used as well.
Tas.
IamElectro
1,470
I had this issue a while back when I created a slipsteamed disk for use in our labs in June. It had something to do with one of the Hotfixes I had intergrated. If I remember correctly it was the Malicious software update. When I recreated the ISO without this hotfix the installation never requested putting the Xp disk back in.
I was using nLite as well.
JasonE4
1,363
I had the same problem, but I did not incorporate any hotfixes. I just incorporated sata drivers so I didn't have to have a floppy drive. I think it has to do with NLite, and I really want to know if there's anything that can be done to fix it as well.
JasonE4
1,363
I searched a couple weeks ago and couldn't really find any other programs like nLite.
