Slim USB 2.0 PC card?
Reading between the lines, I interpret the question to mean, is there a USB 2 PCMCIA card with a dongle so that you don't have that fat end that blocks the other slot or something else?
There is a problem with these fat ended cards - if you have a network wireless card and a USB 2 bard, they both will not fit in most laptops that have stacked PCMCIA slots.
sorry for not being more clear, yes I want one with a dongle so that it's thin.
1 port is enough, I have an IBM X24 with wifi built-in and wanted to keep the card from protuding out too far.
