Slim 120mm fans?
Siba
My lian li A10a, evga 680i mobo and arctic cooling freezer 7 don't fit. The freezer needs about 3mm of clearance from the top 120mm. Does anyone know where I might find some really thin 120mm fans? :T
No such thing.....readily available anyway. Slim 92mm fans are also extremely rare. The only alternative I know about is to epoxy four 60mm fans into a square shape. The resulting edge holes are a close match to a 120mm fan. It could be attached with zip-ties. Of course you'll have to splice wires...
I'd reconsider your use of such a solution however....
Aerocool makes some 140x20mm fans. IDK why no one seems to do slim 120mm fans.
It might be possible to use an Arctic Cooling 120, but I can't see how the fan mounts into that bracket thing so IDK if you could recess that up into that bracket a bit with some type of spacers for mounting...
I can't really get a mental picture of which fan you need - the one in that side bracket, the one on the Freezer or where - and exactly where the clearance problem is?
.bh.
