Without knowing what processor and mobo you have it's difficult to give you a good answer. The Athlon64's have the "Cool 'n Quiet" aspect, provided your mobo supports it in the bios. MSI boards do. I just enabled it on mine, and it does as the name says, keeps it cool and quiet (even more so than the new Lian-Li case does). You'd also be amazed at what a quality case will do for the sound level coming from your computer. With this case, I'll be using ones just like it in any situation where the computer won't be far away from people. Any MCE systems I build will be with either this case, or one that has identical features from the same maker. Hell, it's putting out less noise than my xbox does.
