SLI Water Cooling
TheGeek
I am looking to watercool my 2x6800GT, A64 3500+ system. What water cooling system can handle that? Im planning on overclocking my CPU. Also, are there water cooling blocks for nForce 4? Thanks
Do you plan on overclocking your GT's? If so I'd suggest large exchanger, with high CFM fans, because two GT are going to dump LOADS of heat into your loop, especially if you plan on cooling the GDDR3 too. As it is, they're going to generate a fair amount of thermal energy even if you don't overclock them. 🙂 Do you need specific suggestions? By nForce 4 do you mean the chipset?
I have heard that for SLI systems, DIY water cooling is the best way to go.
Personally, I would try to have 2 loops, one for the CPU and chipset, and another for the 2 6800GTs.
The nForce 3 and 4 chipsets aren't known to generate that much heat. The problem up until this point has been that no blocks were small enough to make plumbing them easy on an SLI rig. I THINK DD has a solution for this now, but so far only for the A8N SLI. Two loops would certainly add "WOW!" to the OP's rig, but it would also add a great deal of complexity for very little real gain in performance.
just go to dd... theres water cooling for everything...
http://www.dangerdenstore.com/product.php?productid=168&cat=67&page=1
for the gpu and
http://www.dangerdenstore.com/product.php?productid=160&cat=46&page=1
if you have an a8n...
http://www.dangerdenstore.com/product.php?productid=17&cat=21&page=1
for your cpu...
I personally would just have one loop... waste of money to have two... just make sure and get a nice big radiator and big resevoir... if you want to do two loops on a single water cooling system you could try getting this resevoir
http://www.dangerdenstore.com/product.php?productid=51&cat=6&page=1
or get two 120mm radiators and put them before the cpu and before the gpu
on mine Im having it so it first cools cpu then goes to 6800's and cools em both... then goes to chipset then goes to raditor then to resevoir then to pump and back to cpu..
oh also if you dont want that big mother of a gpu block there is also this
http://www.dangerdenstore.com/product.php?productid=169&cat=67&page=1
