Slackware7.1 and installation
mikeshn
367
I have downloaded the Slackware 7.1. Currently I use Win2000 pro, how can I install the Slackware from the harddrive?
Thanks a lot
Electrode
6,063
1. Why are you using 7.1? 8.0 has been around for awhile.
2. You'll either need to burn the CD images (ISOs) or download the individual packages.
LNXman
404
If you are trying to install a package that is NOT currently installed, then you use installpkg.
If you are trying to UPGRADE a pakage (i.e. you have an earlier version of the package already installed), then you use upgradepkg.
Make sure you read the man pages for the commands above, especially for upgradepkg.
L8
n0cmonkey
42,936
If you are trying to dualboot you will probably need FAT filesystem on the system, since Linux cant read NTFS. Another option would be to download an iso and burn that like a normal person, or buy the package. Plus, with either of those options you can get a RECENT version instead of something so old. I highly recommend getting the latest because of the slow release of slackware. You will be "stuck" with some old stuff there. If you have FAT32 on the system (WHY?!) you should be able to make a bootdisk and install off of the hard drive. But I would CHECK THE DOCUMENTATION before attempting that. Hell, I would have RTFMIOed this stuff before asking this question...
n0cmonkey
42,936
<< linux can read ntfs it just cant write reliably. >>
I understand that, but its turned off in most default kernels Ive seen. This would *PROBABLY* include slackware.
<< hey n0c whats the IO on RTFMIO? >>
Something I have problems with, In Order ;)
BlackOmen
526
You should really use 8.0 as opposed to 7.1. Otherwise, burning the iso is a straightforward operation, RTFM for more info.
The kernels in Slackware use NTFS as a module.
n0cmonkey
42,936
<< You should really use 8.0 as opposed to 7.1. Otherwise, burning the iso is a straightforward operation, RTFM for more info.
Thanks for the correction, I havent used slackware in a while and have used NTFS even less ;)
