Skyrim announced: Who's actually finished an Elder Scrolls game?
RPD
5,042
547
Finished Morrow Wind, but never got around to completing Oblivion.
Krakn3Dfx
2,969
This is what's going to happen:
It looks great, but because having more than a single disc on the Xbox 360 costs publisher more, the world will be smaller than Oblivion was, because Bethesda isn't going to want to pay extra licensing for 2+ DVDs, so all platforms will suffer.
Later on, we'll get lots of paid DLC that adds more land mass and quests that were originally in the game, but were cut due to previously mentioned DVD restrictions.
Still looking forward to it, but with each game Bethesda releases, it becomes more and more obvious that they're an XBox 360 lead platform developer house.
Dumac
9,391
Looking good. I'm glad they didn't just rehash the same engine.
After playing Oblvion, Fallout 3, and Fallout New Vegas (plus Dragon Knight Saga) I'm kinda over that engine.
Hopefully they use this engine for Fallout 4 as well.
Eh, it is a semi rehash. You can tell in the video. A lot of the graphics scream oblivion, albeit a better looking oblivion.
Wuzup101
2,334
37
I'm actually installing both morrowind GOTY and oblivion right now. I did spend quite some time playing morrowind but never really touched oblivion too much. So yeah... I'm gonna try to play the main quest of both before TES5 comes out :)
simonizor
1,312
I'm ok with that. As long as the world is a little bigger and the dungeons more varied, I'll be happy. The main quest looks pretty good from what I've seen so far.
Dumac
9,391
Yeah, the graphics are fine with me. I actually just tried Nehrim, and the graphics in that were good enough for me...
But yes, I hope they put more effort into the dungeons. I hope they cut back on the level scaling, actually make some stuff by hand instead of generating it, and put a bit more effort into the feel of their world. Oblivion felt so bland, generic, and uninspired. I assume most of the time was spent on getting used to gamebryo and trying (unsuccessfully) to implement radiant AI that the rest of the game got the cold shoulder.
I hope Skyrim is better :p
sticks435
757
It's already been stated that it uses a scaling system similar to fallout 3. Also, there is a soft level cap instead of a hard one. Most of this stuff has been mentioned in the articles on gameinformer or neo-geo.
Dumac
9,391
They were all very vague. The actual implementation could effect things drastically, and is still unknown
Veliko
3,597
127
Despite the hours I sunk into Morrowind and Oblivion I didn't get anywhere near completing them.
To be honest I don't think I will bother with this new game. I started out with Morrowind and loved it but with each successive game after that I got bored with them quite quickly. I lasted about 3 hours with Fallout - it's like playing the same game again but with different graphics.
HybridSquirrel
6,161
i reinstalled oblivion tonight...and didn't play it because it takes for fucking ever to get out of the sewers....i hope they dont have that problem in skyrim. It takes a good 45 minutes to even get started on oblivion which is such a turn off
DeathReborn
2,770
775
I have finished all of the Elder Scrolls games on the PC with the best being Morrowind w/ Exps.
There's a mod for that, here's what it does:
Quickstart.esp:
* Modifies the charactergen script to move you to the exit from the starting sewers when you start a new game. You will start at the door which lets you modify your race, class, and birthsign before exiting into the exterior.
* Sets the quest stages for the main quest properly so you are at the same point you would be if you played through the charactergen dungeon normally.
* Adds a chest near the exit which contains a selection of items which you normally would have found from playing through the tutorial dungeon: light and heavy armor, weapons, lockpicks, potions, gold, torches.
http://www.mediafire.com/?3ikjz27ho19vw7z
It's a godsend after that first playthrough. Usual instqall procedure, bung it into the "Data" folder and mark it in the launcher.
ps: All credit to the mods author etc etc etc...
dennilfloss
Past Lifer 1957-2014 In Memoriam
Oct 21, 1999
30,509
12
dennilfloss.blogspot.com
Just load a game saved at the sewer's exit. I have kept one of mine just for this as I replay often with different races, etc... You can also download them on mod sites.
HybridSquirrel
6,161
problem is, whenever i reformat my pc it deletes all my saves off steam and I never remember to back them up...its like this with nearly every game I own...its such a pain in the ass to start back up I usually end up not playing.
I'll check that mod out.
Imp
18,828
184
But you're escorting Jon Luc Picard! Jon Luc Picard out of the sewers!!! Alone too, yum.
I remember the first time I got outdoors in Oblivion, and saw the Daedra ruins across the lake. I went straight in and cleared it out, then got completely weighed down trying to hump every single item out.
HybridSquirrel
6,161
thats the first thing i did too! lol I ended up using console commands to change my stats so i could carry all the crap in there...
so where do I put this mod? I can't figure it out since I own the game on steam.....*noob mode activated*
steamapps>common>data?
did that, didn't work.
gothamhunter
4,464
I completed Oblivion, and by completed I mean completed - every main and side quest, traveled the entire map, and then continued with mods. I have tried so many times to get into Morrowind, but I never get too far into it :(
I was going to give it another go after that huge Morrowind graphic overhaul mod came out, but now that it's taken down... :'(
dennilfloss
Oct 21, 1999
30,509
12
The ones I remember were just saved games so you juxt copy them to your saves folder. Some are just listed under the character mods. People tend to save those characters just at the sewer exit so you can modify them.
http://www.tesnexus.com/downloads/cat.php?id=43
My saves folder in Windows 7 is located at
C:\Users\Your user name\Documents\My Games\Oblivion\Saves
The vanilla sewer exit save here should be easiest to use of those 4.
http://www.tesnexus.com/downloads/file.php?id=9581
