SK6+ and 80mm fan!
sash1
I just got an SK6+ for my computer! Wahoo, Thermalright rules--used their SK7 before). Anyways, after I ordered it, I checked to see what fans it supported (which I should have checked sooner, dumb Anik...dumb), and it was only rated to hold up to a 60mm fan. Well, I got it today, and I was able to fit on my 80mm 7000RPM vantec fan. :)
This thing is gonna keep my processor extremely cool. I will test it out, as soon as I get some help with mah video card (link if you can help--dun wanna screw anything up)
~Aunix
RadDavy
65
I've been using a 53Cfm 80mm Mechatronics fan on my sk6 as well. Initially I had bought the adapter but I decided not to use it after fitting the fan with the spring clamps. It is a tight fit though. The temp on my 2100+@2250Mhz doesn't go over 112F.
sash1
Well, as cool as this is, it's not working...
I started up my computer and the processor temp skyrockets to above 70C.
Why? It's not on backwards, I thought I may have put on too much thermal compund, but that's just fine...
So...... why?
~Aunix
EdipisReks
2,722
its very easy, with the SK-6, to have a bad contact between the CPU die and the heatsink. one thing to try is to pull the heatsink "backwards" (away from the side you are clipping) while you are clipping it down. do this gently, obviously, but it should help you get a better contact, as the clip design sometimes placed the heatsink a little too far forward and with a little bit of an angle.
RadDavy
65
So...... why?
~Aunix
make sure you don't have the sk6 on wrong. i fried a 1Ghz tbird once by not paying attention. the clip and sink must be oriented the right way. the thumb/screw driver tab must be at the top (in relation to the socket) and the sink touching the lower part of the clip when installed. make sure that the machined recesses match the cpu socket/lock arm position. also, make sure that the wire clips don't hit any capacitors causing problems...
sash1
how do I remove thermal compoundage, do I use isopropal alcohol or what?
Thanks,
~Aunix
sash1
hmm, interesting, I'll try.
~Aunix
sash1
Originally posted by: ChampionAtTufshop
you could use isopropyl (it would be best)
but if not, just clean it nicely with qtip (what i use lol)
Haha, I did the latter actually, didn't have any alcohol.
Anyways, here's a thought, I dun feel any air coming out of the fan (blowing away from the hs), it's definitely running, and at ~7000RPM, think this is a problem, any way to make it blow heat AWAY from the hs? Can I just flip it over or what?
Thanks,
~Aunix
edit- Okay, so I flipped the fan around so it blew heat away form the hs, it actually ran hotter. Oh well. Fun test I did. :)
Blain
An 80mm fan should be blowing fresh air down onto the SK6+ HS. About the only heatsinks that work with hot air being pulled up off the HS are the Alpha pin type heatsinks.
sash1
Just an update (idle temps):
First install: skyrocketed to 70C and shut down
I am a moron fix: 50C
Removed thermal compund: 45C
Did the EdipisReks trick: 37C
Thanks everyone,
~Aunix
EdipisReks
2,722
Originally posted by: Techie333
So you are running it without any thermal compound of any kind?
i think what was meant is that the goop that was preinstalled was replaced with something better.
