Originally posted by: Yield
possible better wear on a higher mileage engine.. there is no harm in going to a synthetic.. i'd say it's good piece of mind.. just make sure you DO NOT put regular oil back in once the sythetic is started.![]()
Originally posted by: notfred
no, but I don't see any benefits to it, either.
Anyway.. its a myth. You do not need to worry about putting synthetic oil in your car. You can do it with 5,000 miles on it, and you could do it with 500,000 miles on it. You could switch back and forth between synthetic and conventional oils every oil change if you wanted to.
not really; the theory (which is viable assuming this) is that older synthetics had harsher detergents in it; they would wash away the carbon deposits of old burnt oil (found in old cars) thereby causing leaks that were not there
Nonsense.Originally posted by: SuperSix
Yep.. Not a good idea to switch over on high mileage cars - it will leak like a sieve.
I would like to understand the thought process behind this way of thinking.Originally posted by: FrustratedUser
What is the point?
You can put synthetic oil in any mechanically sound engine and not think twice. I seriously doubt his '98 is leaking from all its seals.
What is the point?
You own a 10 - 20,000$+ piece of machinery, and you are going to put 98 cents/quart oil, 2$ oil filters and 3$ air filters on it?
It just doesen't make any sense.
I understand the theory behind it, but it is just that; a theory. Synthetic oils do not have harsher detergents in them.. In some cases they have more, but in others, they may actually have less.
Originally posted by: Hamburgerpimp
I wouldn't bother. If you have any leak whatsover right now, then it'll leak even more with synthetic. Personally, I don't think a 100K mile car is worth synthetic. I just changed my new V6 Toyota Tacoma at 1500 miles to Mobil 1 TriSynthetic. If your car was new, it would be worth it.
Originally posted by: gotsmack
what are the benefits of sythnic blends over normal oil and whats the deal with high mileage oil?
It can. As long as you take oil samples every few thousand miles and change the filter every 3,000-5,000 miles, being sure to top off the oil level because the filter will take some oil with it. The oil sample analysis is a pain and synthetic's not expensive enough to bother.Originally posted by: BDawg
What is the recommended service interval for synthetic oil? My SAAB dealer told me to use synthetic, but still told me to change every 3,000 to 3,500 miles. I thought synthetic could go much further.
ZV
