Sister's '93 Escort needs to pass smog (emissions), fix horn, etc
Status
Not open for further replies.
CZroe
24,195
857
IIRC, my sister's 1993 Ford Escort failed the "HC" portion of the Smog Check testing. My sister just got a '96 Taurus that we also need to "get smogged" but that may pass without issue. The Escort, OTOH, just failed it and needs a few other things fixed before she passes it on to her daughter (horn, rearview, etc). Despite Ford's reputation, it's treated my sister well for many years.
I just moved to San Diego, CA from metro Atlanta, GA, so I'm not familiar with the extra hoops CA citizens have to go through with emissions testing ("Smog Check" - though it's technically not "smog" until heat combined with nitrates in the air to create particulates and ground-level ozone). All I know is that 50-state legal vehicles are different than 49-state legal ones because they conform to California's extra requirements. That said, my sister is having a lot of trouble and I can't really help much, so I'm turning to you guys.
When I arrived it was running like total crap... choking, shaking, stuttering, barely staying on/moving at low speeds, etc, until she had some 24yr Ford veteran take a look and tune it up. The difference was AMAZING. The car was so bad that we thought someone had sugared her tank but after the tune up it ran great. She brought it back to these same people when she needed her brake job (and rotor replacement) and they totally ripped her off ($680 after AAA discount).
AFAIK, my sister does not get the oil changed regularly but I would think that it would have been done during the tune up. Regardless, it's dark and I see the oil light come on when turning hard. I've checked the oil level while warm and it appears overfilled. The Smog Check guy said that an oil change would not affect the test, but if it has been neglected, I would think that it might. Heck, perhaps it's time to switch to full synthetic to preserve the engine?
Before failing the test I filled it up with high-test Chevron gas and added Chevron Fuel injector Cleaner like my sister asked (friend's suggestion) and rode it about 35mins on the freeway at high revs (kinda stayed a gear low most of the time). I told her that I wouldn't expect a cleaner to help if it's burning off deposits, and that's exactly what the Smog Check guy told me (too late). "No fuel additives." I'll get the actual numbers when I can.
OK, so the car had a lot of minor issues like a gas gauge that doesn't budge until you are almost empty, blown interior and dashboard lights, loose battery cable, stuck seatbelts, automatic seatbelt track stuck on the driver's side, broken rear-defroster switch, no horn, etc but I'm doing the few I can and it's the horn that I really need help with. I have no way to access it (no jack or tools), but I can still hear the relay "click" when I press the wheel. I found the relay under the steering column and could replace it if I had any way to know if it were bad. I'm told that the light is under the driver-side headlight but the Haynes manual says that I can't get to it without the appropriate jack and I couldn't see it when laying on the ground. They say that I should not use the included jack for anything that involves getting under the car.
I've already done the easy stuff (rearview, seatbelts, interior lights, headlight, etc), and we probably need to take it to someone for the horn and Smog failure, but any advice I can get from you guys would be much appreciated. We can't afford to get ripped off trying to pass Smog and the horn, being very cheap and commonly broken (according to Google), just seems like something that isn't worth paying to have fixed, though I don't have what I'd need to do it myself.
I am NOT a gearhead. never changed oil or took off a panel (until fixing the seatbelts), so even if I had a jack I'd be getting out of my comfort zone.
Thanks.
thedarkwolf
9,028
122
borrow a pair of jack stands/jack/ramp something if you need them to get to the horns. If you hear the relay clicking its most likely the horns themselves that are dead. You can pick up aftermarket generic fit horns at any parts store for $15 give or take. You usually have two a low and a high pitch horn but you can get away with just replace one to pass inspection.
StageLeft
70,150
That car can't be worth even what she paid for the brake job. Is there any way she can replace it with a new one?
bruceb
8,874
111
If you are failing for HC then I would suggest you change the PCV Filter and also replace the O2 sensor or sensors. If either is bad, it will cause the motor to run rich and it will fail the HC part of emissions test.
Bignate603
13,897
Also, you just need a functional horn, it doesn't have to use the original button. It may be easier to wire up another button with an aftermarket horn than to fix hers.
MovingTarget
9,002
115
Yeah, that car is LeMons material just about... but if it were me, I'd just fix it. As long as the engine/transmission are mechanically sound, and the body isn't rusted to hell, then with some elbow grease it will be worth the effort.
first off you are failing on HC..
you know what means.. you got unburned hydrocarbons.. and what kind of fuel are you running??? Premium. Your car is designed for regular. Run regular and get rid of that damn fuel additive and you will pass.
Its not rocket science to pass an older car. New plugs and wires, new air filter, warm up the cat nice and hot and use recommended fuel .. 9/10 times it will pass no problems.
The fact that you didnt fail on the NOx (which is more common) or the CO / CO2 means everything is in spec except you ran premium in that car. The higher flash point of premium means you are getting in incomplete burn and hence your HC problem.
By the way get an oil change.. not that its going to affect your smog, unless you are burning oil. But yeah. Get it if you havent..
nerp
9,865
105
Oh my god. I remember being young and driving beaters. Thank GOD I don't have to deal with that stuff anymore. Wish I could help.
Zenmervolt
Elite member
Oct 22, 2000
24,514
36
Bullsh*t. Pure, unadulterated bullsh*t.
The spark plug will have no trouble igniting the premium fuel. Premium does have a (sightly) higher flashpoint, but the spark from the spark plug is still several orders of magnitude above that point and you will still get a complete burn in a properly-functioning engine.
If he's failing for HC, the car is running rich. This could be a leaky injector, a bad temperature sensor, or a different sensor in the engine that is causing excess fuel to be injected. The root cause is definitely not using premium.
ZV
chucky2
10,018
37
That Chevron injector cleaner isn't really that strong of stuff. Try to see if you can find some Redline SI-1 fuel injector cleaner...might even be in the clearance section.
Dump the whole bottle in on an empty tank, fill it up, and drive it...might go two bottle at once, or two tanks one bottle each in a row.
Chuck
Status
