Sister changed DPI settings...
acid45
Ok, so my sister change the DPI settings (the size of the text)
And now i cant change it back because i cant see anything 🙁
Could anyone help me out here?
The procedure is as follows:
Right-click desktop, and press R, press Shift-CTRL-TAB then ALT-V, press up arrow then hit ENTER, press up arrow again the hit Enter, press ALT-Y then ENTER and reboot. That should reset back to standard 96 DPI.
tried system restore.
And i even manged to go to properties,settings, and advanced but when i click on advanced (this getting me too the DPI settings window) i get a run DLL!!! 🙁
i tried ussing windows last good configuration crap, that didnt work.
so what now?
If it works in safe mode its probably an issue with your display drivers, and they might need reinstalling.
