Need a motherboard.
Looking to get a Pentium 4 board with DDR. Really don't think price vs performance is worth RDRAM anymore.
Basically the two chipsets I am looking at is the SIS648 or the 845PE.
Now as far as the boards. For the SIS boards I would probably get the Giga-byte 8SG667.
When it comes to the PE board, I am not sure if I should go with the Albartron PE or the Asus PE.
I really don't overclock all that much however overclocking is not out of the question, but not a priority when buying.
Budget is medium, I spend the money if its worth the price.
Also any insight on a case would be appreciated.
Thanks alot for any advice you might have
